First of all i didnāt draw sprinkler in fire protection system. Because you canāt calculate flow value in fire protection system so i set the pipe system to hydronic system and set all sprinkler flow value to ā1ā.
This way i can see how many sprinkler connected to the pipe.
So i use āelementgetparameterā to get flow values on pipes and change pipe diameter according to sprinkler quantity by āelementsetparameterā.Try it with this way if you fail i will help you again.
Dear Memet,
I impressed by your idea, It works for sure, but could you please give me a brief explanation about your code? Or is it possible for you to share it with us?
Thanks in advance.
I would actually suggest making your sprinkler connectors and sprinkler systems as āDomestic cold waterā so that they use Fixture Units instead of Flow. Flow has units, so if someone changes from l/s to m3/h it will no longer have a value of 1. Fixture Units are always a unitless number value.
When i am adding flow to sprinkler it is not getting reflected in the pipeā¦Can you tell us the custom packages used in your scriptā¦Thanks in advance
