Hi, I want to pipe the pipe using excel, but I have not managed it. I would like to ask for your help
Hi, just to clarify. You are looking to adjust the diameter of existing pipes in revit, based on an excel file that pairs flow rate with required diameter? Also, what is the content of the python script?
I am exporting the excel file. According to the number of sprinklers in the excel file, we want to scale according to the numbers I specify in excel.
asd.xlsx (9.9 KB)
Did you ever manage to get this to work?
Yes, I’ve now succeeded in making all pipe diameters with dynamo.
Hi mekanikist,
could you please share the pipe sizing dynamo graph that solved the problem. I am also having a similar task,
Thank you
Musisi
