Hello.
I have an issue with a node Springs.Element.MeshGeometry
This now for some reason just doesn’t want to read one element which Exported IFC element from Tekla.
More over I have hundreds of other elements like this and this node handle them very well. But when this strange element come to the selection with other elements this Node simply stop working. And it doesn’t show any errors.Gives just nothing. Any ideas what is that ?
And maybe you can advise me some other packages that can read the meshes. Because basic Dynamo nodes can not read this meshes at all.
The packages i use for Mesh geometry are MeshToolkit and SpringNodes ( but i’m still on 1.3x) @Dimitar_Venkov creates the SpringNodes package, maybe he can help
I don’t know how big your project(s) are, but when these operations become large, meshing individually can get very slow.
I would mesh just 1 of a particular size and copy it around. This might also help avoid any corrupted elements.
Hope that helps,
Mark
Edit: it’s possible that if you get the parameters of the nulls and their location points and rotations, you could copy an adjacent one into the new position?
