Hello there,
I have been trying to split pipes/ducts networks into the desired length with a coupling but there are some issues.
I have gone through some earlier posts regarding splitting pipes but they have their own problems.
Please suggest.
Split Pipe for divisions_1.dyn (29.1 KB)
Hi @theshysnail,
You can use the Split ByPoints custom node:
Split Pipe for divisions V2.dyn (24.0 KB)
Hello, thanks for the script “Split Pipe for divisions V2”, it works perfectly, but when I want to split electrical conduits, the GeniusLoci_Split ByPoints node doesn’t work because it’s only for pipes and ducts. Do you know a node that can split electrical conduits or some script? Thanks in advance.
Hi @elmercchGKJEK try this one here from OpenMep…should work on conduit
Translated by moderator. See below the line for original post.
Why is it not separating the pipes in my case?
Original post below
Woran kann es liegen dass es bei mir die Rohre nicht trennt?
Welcome to the forum @mandy.kasterLACQM.
The language here is english, which sadly is a requirement for search to work (eller så skulle jag öva min svenska i alla mina inlägg), and search is a very important part of the service which the forum provides (in fact it’s likely how you found this 5 year old topic).
Please translate your posts in a translation service of your choice going forward, optionally keeping your original post below a separation indication as I did in my edit of your post. Thanks!
