paris
September 21, 2021, 4:24pm
8
Hi @jacob.small thanks for your reply, I think that if you delete a old pipe to recreate a new one, you lose some parameters for e.g. comments/marks/connections/workset. The question how to split pipes has already been solved by @Alban_de_Chasteigner
Hello there,
I have been trying to split pipes/ducts networks into the desired length with a coupling but there are some issues.
I have gone through some earlier posts regarding splitting pipes but they have their own problems.
Please suggest.
Split Pipe for divisions_1.dyn (29.1 KB)
[image]
and by @maciek.glowka
hi @paris
as for the null values - I am sorry but there was a mistake in the output part of the script.
This is the corrected version, that should not produce null values (unless there is a reason for that)
However I think the unassigned system problem is still there - judging by the pipe colours.
As I probably said before, I have never used much MEP part of Revit and do not have much knowledge on it specifics. I do not have any ideas now about those unconnected caps and tees (don’t really k…
Cheers
