Some one have one idea?
Are you wanting to separate out ducts less than that length or actually split the model element?
Hi Josue.
Can you be more specific with your question.
Split all the ducts in sections no more than 49".
Hi J_Josue_Correa
I’m having the same problem and i will thank a lot if somebody know how it can do it.
Have you a solution already?
Thanks a lot in advance
And you end up with unconnected ducts/unions.
Hi Erfajo,
I am new to revit and dynamo and if I ask any stupid question please dont mind. I tried your DuctByLengthUnionConnected.dyn and it worked like a charm. We use 1400 lengths for duct and I changed your code slightly.
Secondly, If i replace the first two nodes with a select model element node, it works great for the first pass and if i draw new ducts and try to re-run the code it. it will undo the first pass (joint the elements it split in the first run) and splits the elements selected. Can you please advice me what changes I have to make to fix it.
CheersDuctByLengthUnionConnectedSelectElement.dyn (33.2 KB)
DuctByLengthUnionConnected.dyn (33.5 KB)
Thanks Erfajo
Hi ,
- Why I’m getting first item as 1400 and remaining to be 1395
- Ducts got Splitted from the Elbows/Joints
- Archilab node didn’t work for me so I added Tool.eraser by steamnode
Duct split.dyn (74.3 KB)
I did. Duct/Pipe Split
