Would it be possible to specify the location of an area line, Finish Face: Interior or Exterior. For our GFA or FAR calculations sometimes we count the wall and sometimes we don’t.
Not easily. These are only set at creation and then lose all relation to the walls. Hence when you move a wall the area lines don’t automatically update. You could look at getting the lines for every core and finish face of every wall, and try intersecting that with area lines as one option.
I use the Roomboundary curves from a special room i create outside the building.
This Room will find the outer Wall’s exterior.
With Dynamo i can get the boundaries of this Room and create Area Separator lines from it
Then delete the ones you dont need.
