Solid(s) aren't being identified within family
I have some families where there is non-nested geometry but dynamo won’t recognize that there’s geometry in the family. This is happening for all the sprinkler families, and for some plumbing fixture families but not others.
I’ve checked and the detail level of the families is set to medium, and I’ve tried it on every Geometry scale.
For reference I have stripped down a family as a sample.
Sample Sprinkler.rfa (512 KB)
Hello @RDM try Element.Geometry+ from clockwork and see if it could work
I did try the node but only with the default settings which output empty lists.
After some testing it works if the node input uses ‘Fine’ as the input, thanks for the suggestion.
I hadn’t considered even though the default family was set to Medium, the geometry itself was set to only display on Fine detail.
If I set my 3D view to Medium detail, only the ‘DetailLevel’ input consistently output the solids. The ActiveView will also output the solids but only if I set the 3D view to Fine detail but using the Fine detail saves me from using a 3D view.
