Hi All,
Image to objects
First time I run this, I get it working & get the preview as per the screenshot
But the moment I change the value of 50 (reduce or increase), the operation fails - Can anyone explain why? Is there a maximum of 2500 as a count somewhere?
Even if the value is reset back to 50, still it doesn’t help!
Other error is Brightness Operation Failed… Donno what’s wrong!!
Assuming this is like a frit pattern on the curtain Panel, I need to use this to be “overlaid” on curtain panels
Think the following steps will take me there - Correct me where I am wrong…
After this part works, next step is to select curtain panels & generate Work Plane from Curtain panel (Plane from Panel) - Is there a better way to do it?
Use the list of center of circles & list of radii to create circles on that Work plane OR
Use Place family instance with the list of center points within Revit (which will give the flexibility of changing the family instance from within Revit)
Will need to use Dynamo only if the whole base image needs to be changed
Will this concept work? Or is my approach not going to yield good results? Any advice will definitely help.
Thanks!
