Is it possible to create a filleted corner on a solid body that is simply curved?
I’ve tried multiple approaches and end up with this result. I have an idea that it’s due to the arc creating the filleted corner. It’s staying in plane, not projecting correctly as the surface curves.
To work through the problem I tried spline through points and also reference line which follows the surface u/v. However, Revit still doesn’t create the proper filleted corner (always results in unwanted lines.)
I’d be grateful to any suggestions!
