Sheet numbering as combination of different Parameters (Solved)
Hi everyone,
I´m really new to Dynamo. I´m tring to get the sheet number Parameter as a combination of different Parameters.
I found this example but unfortunatly is not working. https://livingroomcraftz.wordpress.com/2018/10/20/we-care-a-lot/
I get actually no wrong messages
any idea?
Plane is german for Sheets i guess? Try this:
Hi Schasfoortyoeri,
thank you for the suggestion. I´ve been tring with the Codeblock as you suggested and something seems moving but not working.
Dynamo try to override the sheetnumber just with the three “_”, Looks like the Parameters are not successfully read.
Are these Sheet parameters?
yes, as Shared Parameters
Could you upload a Revit file? Im not an expert but i can do some trail and error
this is my actual Dynamo screen. I dont know why but i can´t get the four Parameters…
Revit wont let you rename Sheetnumbers to all be “___” it should be all unique entries
thanks m.rijsmus,
yes this make sense, but i cant do that…
He wants it to be unique entries.
a = value of parameter Plantyp
b = value of parameter Ifd.
etc.
my geus is these parameters vary per sheet
Sheetnumber = a + "_" + b + "_" + c "_" + d
HI all, thank you!
now is working!!! but just for some of These.
How to remove this “==” Code block on top?
That == node is checking if the sheet parameter Plantyp isnt “” (empty)
you could leave it out, but if its empty it will result in Sheetnumbers like this:
Sheetnumber = _b_c_d
starting with _
Thank you all!! I almost archive what i was looking for, i just need now to put everithing together.
I have few more Questions:
  1. one of These Parameters are actually always the same, so i could replace it with a fixed “AB” for example. Any Idea how to do this?
  2. I would like to put the revisions number in the end… but it is not a sheet number…
that can be done just as you typed it…
or:
Thank you very much!
Do you think is possible to add the “Revision number” Parameter?
Use the same method as before to add it to the parameter :slight_smile: this is how you could get revision info from sheets.
You are Right! I just added the Parameter in the same file and it is working well :slight_smile:
Glad it worked! Can you mark a post as solution so others can also learn from your question?
Hi everyone again!
I´ve been using this script more or less in a good way, the sintaxt of my Plannumber is: “FRA”+""+a+""+b+""+“AOB”+""+c+""+d+""+e+""+f+""+g;
G is my Revision Parameter.
I would like to have the underscore “_” before the last Parameter G (Revisionparameter) just when true is.
Any idea?
