Sheet.Duplicate with schedules
I have been using the bimorph Sheet.Duplicate node to duplicate sheets with views on them for awhile with no problems, but recently we decided to add a schedule to several sheets in our template. When using my dupplicate sheet graph I realized that this node does not duplicate the schedule at all, it just places another instance of it on the new sheet created by the node. Does anyone know if there is a work around to get the schedule duplicated with this as well?
That’s how it’s designed to work to avoid unnecessary profligation of views. The great thing about Dynamo however is that you can develop your own scripts to suit your workflow: find a duplicate view node, dup your schedules, then delete/replace the schedules from the sheets with your duplicates.
You could check my post where I shared solutions for copying legends and schedules on multiple sheets. As @Thomas_Mahon said, you can try to manipulate to fit your needs.
thanks
