I’m currently creating sheets automatically in my project. The problem, is that the used node wont place the Views to the Sheets, because the Views are bigger than the Sheets. I need this node to ignore this warning and place them anyway. Is it possible?
You could try cropping them before placement, but otherwise I don’t think you can ignore the warning.
I was able to solve it.
- First I have a dynamo file, what changes all of my View Template, to a scale 1:500.
- Then I create the sheets, with the Views
- Then a third dynamo file to change the View Template back
You could try to use a titleblock that is 10,0 x 10,0 and replace the titleblock after placement maybe?
