Create Sheet with views Error
How can we fix this error? All views are normal with the correct sheet name and sheet number
The view is bigger than the sheet. Crop it to a smaller portion of the model or change the scale to something smaller.
Thank you! that’s the reason. Because I already have applied crop box and crop annotation for views. But I’m not sure why some sections not be cropped that cause big view.
Hard to say - best that you open the model and look at the view itself. The crop may be off, or if you are trying to create, crop, and place the view then you may need to add a transaction.End and a Transaction.Start node between assigning the crop and placing it on the sheet.
@jacob.small
Out of curiosity. Why can i place a View, which is bigger then my Sheet, manually,
but not with Dynamo?
Think this is an added warning as people are apt to ‘automate’ printing as well. With the UI people tend to see the issue pretty much instantly (if not before they finish) while there is no certainty anyone sees the issue until you’re staring at a PDF of mostly blank paper.
