Have been trying to set pipe invert and noticed this culprit. Am I doing anything wrong?
@craigp can you run this a few times? unfortunately I could not find a very clean solution to set the inverts at start and end at the same time, but it should converge after a number of times.
Sorry didn’t get you. Can you show me one example how to do number of times?
I’ve recreated your values.
In the Toolkit you get the actual invert for a real pipe with the cross-section that is orthogonal to the centerline (in red).
In Civil 3D you get an abstract pipe (in blue) with the cross-section always vertical, reagardless the slope. With an 85.7% slope this is the difference that you see.
In the Toolkit, the Invert takes into account the slope, hence the difference in the value in the properties.
Thanks Paolo. I am not seeing the same what you’re getting. Could you please try on this dwg file.
Set Invert.dwg (946.1 KB)
Here is the dyn file:
Set_Invert (1).dyn (38.9 KB)
Thanks a lot paolo. But I can’t find the same node which you have Set Invert. You will publish the latest package?
What should I do so that it comes down to center? How can I fix this issue?
to do what you want you need to set the StartPoint / EndPoint of the pipe not the invert…
