Pipe.setinvert , any idea?
Hi
Check
Geometry Scaling was set to Large or Extra Large
Can you take some screenshot on the error messages?
its already extra large
As a rule of thumb, leave the geometry scaling set to Medium. There are many issues that can arise if it is changed.
i tried medium also
There are differences between Camber and Civil 3D Toolkit and you can’t combine some of the nodes
In the attached picture you get the same result but if you use the “PipeNetwork.GetPipeNetworks” from Camber you also get the opportunity to decide if you want to include DREF Pipe Network or not
thank you @patrick.ericson
No worries Aravinth.
Glad to be able to help :slight_smile:
