i want to know if it is possible to set anything to the net floorlevel.
system familys are easy they stay at the same high, but anything else change the high and busted the model. Does anybody have a solution?
Hi annikruell
Can you please explain clearly what you are trying to say
Hi there,
On one hand, you could get the reference level and the offset of an element. On the other hand, you could get the Level Elevation.
With those data, you could do it without any problem what you want.
e.g.
Level 0: Elevation = 0
Level 1: Elevation =2000
Item: Reference Level = Level 0
Offset = 1000
You could just change the The Item reference level to Level 2 and the Offset to 1000(Initial Offset)-2000(Level Elevation)= -1000.
Cheers
Manel
is draw the pipe and the pipe moldings at level " UKRD"
but for the ifc export it is better that everything is at the floorlevel (i don’t know the right word)
so if i change the level from the pipe moldings the height does not adapt to like the pipe.
Currently some pipes refer to the top and others to the bottom and thus also their moldings.
I draw the pipe and the pipe moldings at level " UKRD"
but for the ifc export it is better that every object is at the floorlevel (i don’t know the right word)
