Duct fitting elevation
I am mep bim modeling and I have to render with revit in lod 400, i have a problem to set the correct level with duct fitting when the level does not correspond : if I move the correct level with duct fitting another element changes an elevation.
I can’t resold the issue and i asked autodesk hot line and they have no solution yet.
I would to know there is a solution with dynamo.
Hi @yiningparis,
You can use the Element Change Level custom node of the Genius Loci package for this task.
if you don’t have packages just used below python script.
input-01 element
input 02 level
clr.AddReference(‘RevitAPI’)
element = UnwrapElement(IN[0])
ref_level = UnwrapElement(IN[1])
listout =
for i,x in enumerate(element):
ref_levelid = ref_level.Id
#familyinstances
try:
	object_param_level = x.get_Parameter(BuiltInParameter.FAMILY_LEVEL_PARAM)
	object_level = doc.GetElement(object_param_level.AsElementId())
	object_param_offset = x.get_Parameter(BuiltInParameter.INSTANCE_FREE_HOST_OFFSET_PARAM)
	object_newoffset = object_param_offset.AsDouble() + object_level.Elevation - ref_level.Elevation
	object_param_level.Set(ref_levelid)
	object_param_offset.Set(object_newoffset)
	listout.append(x)
#system families
except:
	try:
		object_param_level = x.get_Parameter(BuiltInParameter.RBS_START_LEVEL_PARAM)
		listout.append(x)
	except:
		pass
OUT = listout
Hi Alban,
it works and now i’ll try with the python script after i would to create a script who set a correct level automatically.
It’s ridiculously easy with the Closest Level node, still in the Genius Loci package.
