I think it’s a bug…
I can’t select each elements…Can only select with drag area…I need select as click to object.
It’s not a bug. It’s not implemented. I think there are packages that have this functionality. Try installing Spring Nodes package for example.
ok thank…how can I send to autodesk programmer?
Pick model elements in rhythm has this option.
And the way to send to Dynamo team is pull request through Github.
An alternative way to go about doing this is to select the objects first in the Revit UI, temporary isolate and then select all elements. But if spring nodes has this already just use those as they are really good tools to have in the toolbox.
Cheers,
Dan
