IGU
1
Hi everyone,
I am trying to create schedules with the ScheduleView.CreateSchedule node.
At first it works fine.
But, once I try to change the Category it doesn’t create a new schedule.
It seems to keep in memory the first schedule. Any ideas?
Thanks!
Haaba
2
Hi!
Is the update automatic or manual? The graph might not have been updated after your change of category.
IGU
3
Hi Haaba,
Thanks for your answer.
I tried both and it’s still not working.
Any other idea?
IGU
4
The only thing that seems to be working is disconnecting and connecting the Schedule Type before running the script.
As you can imagine, I would rather not have to do that every time.
IGU
5
And not even because it just overwrites on the schedule created before…
Haaba
6
You can have a look in this thread.
I think you have to make a small change in your graph to make Dynamo calculate over again.
https://forum.dynamobim.com/t/dynamo-scripts-not-updating-output-functions-when-a-change-is-made-in-revit/14218
Try leveraging Dynamo Player for this graph, as it should create the schedule and do so in a way without element binding.
