RoomSpaceSeparator I can generate model lines all day long with the attached graph. Unfortunately, I need to create space separator lines to fix an issue on a project. I thought I could use the RoomSeparator.FromCurve node as a starting point, but I can’t get it to work.
As you can see in the attached graph, I copied the RoomSeparator.FromCurve node and edited the python to create a spaceseparator.fromcurve node. Didn’t work. So I wired up the RoomSeparator.FromCurve node. Didn’t work. So I added ModelCurve.ByCurve. Bingo! Lots of model lines…but I need spaceseparator lines.
I would love some help with this before I pull my hair out.
Thanks,
~Richard
