Hi everyone, I’m trying to create Space separator from Curves, So using Clockwork node"SpaceSeparator.FromCurve" is not working, then I bring python script into my graph but it shows below warning. then basically I don’t python so can you Copy Element From Linked Model.dyn  (30.6 KB)
elementlist = list()
Revit Version - 2015
              Hi @thiru2jack ,
Can you show us the rest of the graph?
thank you Mr.@CVestesen  but i dont know how to solve it…
              i think the sketch plane can be a level
              still,
  it shows the same warning
@Marcel_Rijsmus
              can you draw a space separator in a 3d view in Revit???
              @Andreas_Dieckmann
              It is telling you that it is not made for getting a list of sketchplanes… Your IN[1]
Edit… This is because it is made to be within a custom node which handles the iteration through dynamo
                SeanP
                    January 17, 2019,  4:57pm
                  10
              You either need to give it only ONE sketchplane, or you need to modify the code to iterate each plane with each curve in each view.
              Try using this one in your python script:
if isinstance(IN[1], list):
              yes, @SeanP  I did each plane for each Curve but now it shows this error.
              Sorry For late reply, i did this changes for curves and sketchplane but it shows the same error so iterate each sketchplane for each curve but it shows
              Can you share the code again?
              yes,
view = UnwrapElement(IN[2])
Copy Element From Linked Model.dyn  (71.7 KB)
                SeanP
                    January 19, 2019,  4:00pm
                  17
              You have the sketchplane and the curves coming in on IN[1] in the code above. Change the curves to IN[0] and see if that works.
              no, it shows the same the error,
separatorarray = doccreation.NewSpaceBoundaryLines(sketchplane,curvearray, view)
this line is correct or not ??
where do i check?
separatorarray = doccreation.NewSpaceBoundaryLines(sketchplane,curvearray, view )
these three variables are only needed or these variables are correct order ??
                SeanP
                    January 19, 2019,  4:24pm
                  19
              It appears to be in the correct order.
http://www.revitapidocs.com/2016/e95433bf-3440-50e3-c9d0-c5559fbb0aff.htm
However, I think k your list structures aren’t working right. You have nested lists of curves coming in, but you only iterate o er them all one time. IE: Curve List 0 has 4 curves in it, but you never get curve[0][1]. You just add them all to curvearray.  Try to work through your lists and make sure they are all matching and at the same level.
              i tried, Nested curves with 4 plane and Nested Curves with Nested Planes and also change the views but
but i try with model line. it’s working
