Rooms from linked model filtered by Design Option
Hello All,
I have an Arch model that contain several design options, linked to our MEP model.
I tried to use Revit Space Naming utility to match the name of spaces created to the rooms from Arch model. It didn’t work and a bit of searching online, suggest that it won’t work because of the design options :frowning:
So I decided to have a look at dynamo. This part of the graph I have shared below is to collect all the rooms from a Design Option (Primary) that I have highlighted from the Arch model.
But it seems like no matter what design option I pick, the graph always gives same result, rooms from design option 1 (0 on the list).
To double check, I have opened the Arch model and searched Element by ID and rooms listed are from design open 1?
Could someone please help me to resolve this issue?
Hi @Hoss,
It is working fine for me. Verify the value in the Ouptut in of the FilterByBoolMask.
This issue comes probably from your filter.
Hello @Alban_de_Chasteigner
Something catches my eye here, i don’t see list lengths
Why?
For the lists, they are present and not exported in the image.
For dictionaries, remember that this is an unordered set.
Hello
Thank you very much for your help
It looks like I over complicated my graph, yours working fine.
Thanks again for your help
