Revit | Dynamo | Duplicate Sheets with Views - PROBLEM
HI,
I tried to follow this video to dublicate sheets and views but im doing something wrong that i cant find a solution for. The run function results in “Run completed with warnings” and i never get the extra window - Select sheets to dublicate.
WARNING: Warning: One or more of the input types are not matching. Couldn’t find a version of Duplicate that takes arguments of type (string,string,null,null,null,null)
Here is a screashot of my dynamo window. https://ibb.co/ngmeAT
Is ther anynone who can see what im failing at?
With kind regards, Victor
Have you looked at the node previews? What do the errors say?
MultipleInputForm ++ returns User Inputs as a single sublist. You’re probably trying to pull from outside the index range.
Hi and thanks for trying to help.
Starting from the left and then from up to down the errors say:
Warning: List.GetItemAtIndex operation failed.
Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
Warning: String.ToNumber operation failed.
Not a valid number.
Parameter name: str
So it sounds like it’s exactly what I suggested. Your user inputs are a list within a list and you’re pulling from level 2 (the outside list) which only has a single item. Look at the MultipleInputForm ++ output. You need to use list level @L2 for your GetItemAtIndex nodes.
I dont know how to do that. (I double clicked the UI.MultipleInputForm ++ window and wrote @L2/L2 in the Output window.)
Can you pin the node preview of UI.MultipleInputForm ++ or attach a watch node so we can see what the output is? It’s almost impossible to tell what exactly is going on without being able to see what’s happening.
ok, i will try that.
It also looks like you’re using an older version of Data Shapes. You might try updating to the newest version.
I shoul have the latest update for Revit 2016 but I will have a look.
I have Data-Shapes 2016.12.31
This is as far I can get today.
So one of your inputs is wrong and the node is failing. Looks like ColorSelector is the issue.
Thanks, I will try to figure this out tomorrow.
Do you have any clue what ColorSelector could be?
Now i see that i have a conflcit with my Dynamo, something related to RevitAPI which I read could have to do with Dynamo color picker.
System.IO.FileLoadException
Dynamo has detected a conflict with a dependency and may be unstable. If any issues are detected, please uninstall addins or packages and contact the provider.
While loading assembly BimorphNodes, Version=2.2.9.0, Culture=neutral, PublicKeyToken=null, Dynamo detected that the dependency RevitAPI, Version=17.0.0.0, Culture=neutral, PublicKeyToken=null was already loaded with an incompatiable version. It is likely that another Revit Addin has loaded this assembly, please try uninstalling other Addins, and starting Dynamo again. Dynamo may be unstable in this state.
It is likely one of the following assemblies loaded the incompatible version:
UIFrameworkInterop, UIFrameworkInterop, UIFramework, UIFramework, UIFrameworkServices, AddInManagerUI, AddInManagerUI, APIInterop, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, RevitAPI, GeomUtilAPI, GeomUtilAPI, GeomUtilAPI, GeomUtilAPI, UtilityAPI, RevitDBAPI, RevitDBAPI, RevitDBAPI, RevitDBAPI, RevitDBAPI, RevitDBAPI, FamilyDBAPI, FamilyDBAPI, FamilyDBAPI, FamilyDBAPI, FamilyDBAPI, FamilyDBAPI, EssentialsDBAPI, EssentialsDBAPI, EssentialsDBAPI, EssentialsDBAPI, EssentialsDBAPI, EssentialsDBAPI, GraphicsAPI, GraphicsAPI, RoomAreaPlanDBAPI, RoomAreaPlanDBAPI, RoomAreaPlanDBAPI, RoomAreaPlanDBAPI, RoomAreaPlanDBAPI, ArrayElemsDBAPI, ArrayElemsDBAPI, ArrayElemsDBAPI, ArrayElemsDBAPI, ArrayElemsDBAPI, StructuralDBAPI, StructuralDBAPI, StructuralDBAPI, StructuralDBAPI, StructuralDBAPI, StructuralDBAPI, HostObjDBAPI, HostObjDBAPI, HostObjDBAPI, HostObjDBAPI, HostObjDBAPI, HostObjDBAPI, SculptingDBAPI, SculptingDBAPI, SculptingDBAPI, SculptingDBAPI, SculptingDBAPI, ElementGroupDBAPI, ElementGroupDBAPI, ElementGroupDBAPI, ElementGroupDBAPI, CurtainGridFamilyDBAPI, CurtainGridFamilyDBAPI, CurtainGridFamilyDBAPI, CurtainGridFamilyDBAPI, SiteDBAPI, SiteDBAPI, SiteDBAPI, SiteDBAPI, SiteDBAPI, DetailDBAPI, DetailDBAPI, DetailDBAPI, DetailDBAPI, DetailDBAPI, BuildingSystemsDBAPI, BuildingSystemsDBAPI, BuildingSystemsDBAPI, BuildingSystemsDBAPI, BuildingSystemsDBAPI, BuildingSystemsDBAPI, BuildingSystemsDBAPI, EnergyAnalysisDBAPI, EnergyAnalysisDBAPI, EnergyAnalysisDBAPI, AnalysisAppsDBAPI, AnalysisAppsDBAPI, AnalysisAppsDBAPI, AnalysisAppsDBAPI, StructuralAnalysisDBAPI, StructuralAnalysisDBAPI, StructuralAnalysisDBAPI, StructuralAnalysisDBAPI, StructuralAnalysisDBAPI, StructuralAnalysisDBAPI, RebarDBAPI, RebarDBAPI, RebarDBAPI, RebarDBAPI, RebarDBAPI, AssemblyDBAPI, AssemblyDBAPI, AssemblyDBAPI, AssemblyDBAPI, APIDBAPI, APIDBAPI, APIDBAPI, APIDBAPI, APIDBAPI, APIDBAPI, DPartDBAPI, DPartDBAPI, DPartDBAPI, DPartDBAPI, StairRampDBAPI, StairRampDBAPI, StairRampDBAPI, StairRampDBAPI, StairRampDBAPI, InterfaceUtilAPI, InterfaceUtilAPI, InterfaceUtilAPI, InterfaceUtilAPI, InterfaceUtilAPI, InterfaceUtilAPI, InterfaceAPI, InterfaceAPI, PointCloudAccessAPI, PointCloudAccessAPI, NumberingDBAPI, NumberingDBAPI, NumberingDBAPI, NumberingDBAPI, MassingDBAPI, MassingDBAPI, MassingDBAPI, MassingDBAPI, RevitAPIIFC, RevitAPIIFC, RevitAPIIFC, RevitAPIIFC, RevitAPIIFC, IntfIFCAPI, IntfIFCAPI, AddInManager, AddInManager, AddInManager, KeynoteDBServer, StraightSegmentCalculationServers, FittingAndAccessoryCalculationServers, Revit.IFC.Export, Revit.IFC.Export, Revit.IFC.Import, Revit.IFC.Import, AddInJournaling, RevitAPIUI, RevitAPIUI, RevitAPIUI, RevitAPIUI, RevitAPIUI, RevitAPIUI, RevitAPIUI, RevitAPIUI, RevitAPIUI, RevitAPIUI, RevitAPIUI, RevitAPIUI, BuildingSystemsUIAPI, BuildingSystemsUIAPI, BuildingSystemsUIAPI, BuildingSystemsUIAPI, RevitUIAPI, RevitUIAPI, RaaSApplication, RaaSApplication, RaaSApplication, RaaSApplication, RaaSApplication, RaaSApplication, RaaSApplication, RaaSApplication, AutoLoader, AutoLoader, FabricationPartBrowser, FabricationPartBrowser, FabricationPartBrowser, FabricationPartBrowser, FabricationPartBrowser, KeynoteUIServer, KeynoteUIServer, MemberForces, MemberForces, MemberForces, ObjectNumberingUI, ObjectNumberingUI, ObjectNumberingUI, SectionProperties, SectionProperties, SectionProperties, SectionProperties, AREXRevitStart, AREXRevitStart, BIM360GlueRevit2016Addin, BIM360GlueRevit2016Addin, BIM360GlueRevit2016Addin, BIM360GlueRevit2016Addin, SSONETUI, SSONETUI, SSONET, SSONET, DynamoRevitVersionSelector, DynamoRevitVersionSelector, DynamoRevitDS, DynamoRevitDS, RevitServices, RevitServices, IFCExportUIOverride, IFCExportUIOverride, IFCExportUIOverride, Revit.IFC.Common, Revit.IFC.Common, NaviateA, NaviateA, CQRevitAPI, CQRevitAPI, CQRevitAPI, CQFilter, CQFilter, CQAcoustics, CQAcoustics, CQFire, CQFire, CQBCF, CQBCF, CQBCF, CQBuildingCoder, CQBuildingCoder, CQColumnSharedCoordinates, CQColumnSharedCoordinates, CQCutout, CQCutout, CQDoorSwing, CQDoorSwing, CQDWGTracker, CQDWGTracker, CQElementSplit, CQElementSplit, CQExportKof, CQExportKof, CQFi2Export, CQFi2Export, CQFireLegend, CQFireLegend, CQMergeParameters, CQMergeParameters, CQPlacing, CQPlacing, CQRoomCopy, CQRoomCopy, CQRoomData, CQRoomData, CQRoomDrawings, CQRoomDrawings, CQScheduleExcelExport, CQScheduleExcelExport, CQScheduleLevel, CQScheduleLevel, CQSectionView, CQSectionView, CQSharedElevation, CQSharedElevation, CQSheetManager, CQSheetManager, CQSISArea, CQSISArea, CQSosiImport, CQSosiImport, CQVipEnergyExport, CQVipEnergyExport, CQWallAlign, CQWallAlign, CQWarningHandler, CQWarningHandler, CQWindowSwing, CQWindowSwing, ISY.CAD.Revit.Rebar, ISY.CAD.Revit.Rebar, NaviateAConfiguration, NaviateConfiguration, NaviateConfiguration, NaviateHelp, NaviateHelp, NVarray, NVarray, NVCreateDependentViews, NVCreateDependentViews, NVElementRenumbering, NVElementRenumbering, NVLegendByCategory, NVLegendByCategory, NVPublish, NVPublish, NVTiffExporter, NVTiffExporter, NVTransferProject, NVTransferProject, RevitAPIUIMacrosInterop, RevitAPIUIMacrosInterop, RevitAPIMacrosInterop, RevitAPIMacrosInterop, RevitAPIMacrosInterop, AddInJournalClient, REX.ApplicationServices, AREXRevitMngr, AREXRevitMngr, RSEnterpriseClientInterop, RSEnterpriseClientInterop, RSEnterpriseClientInterop, RSEnterpriseClientInterop, RSEnterpriseClientInterop, RSEnterpriseClientInterop, RSEnterpriseClient, RSEnterpriseClient, RSEnterpriseClient, RSEnterpriseClient, RSEnterpriseClient, RSEnterpriseClient, MacroHookup, MacroHookup, RevitAPIBrowserUtils, RevitAPIBrowserUtils, RevitAPIBrowserUtils, RevitAPIBrowserUtils, DynamoRaaSHelper, RevitNodes, RevitNodes, SimpleRaaS, SimpleRaaS, RevitRaaS, RevitRaaS, RevitRaaS, RevitRaaS, RevitRaaS, RevitRaaS, RevitRaaS, DSRevitNodesUI, DSRevitNodesUI, DynamoRaaS
Oh. In that case you may try uninstalling and reinstalling Dynamo. I dunno if Data-Shapes has any known conflicts. @Mostafa_El_Ayoubi?
I will try that.
The error report seems to be related to bimorph package.
Yes please update the package and let me. Know if the error persists.
Yuuuup…
@VicBerg can you show the rest of your graph? Are you using any Bimorph nodes?
I downloaded the file from here, https://www.youtube.com/watch?v=39koO3tFgoo
Required packade are: BimorphNodes, LunchBox and Data-Shapes
BimorphNodes is the latest version. 2.2.90
Try removing Bimorph and Data-Shapes. Uninstall Dynamo (completely). Reinstall and re-download latest packages.
