Revit 2023 Player Missing
New install, Windows 11. Player is grayed-out. Ran the <ResetUI.bat> to no avail. Player doesn’t seem to be off-screen.
New install of Revit 2022 on the same computer comes in fine.
Any clues?
Best to reach out to support via the accounts portal (manage.autodesk.com) so we can get this logged with development.
Does this comparison of 2022 & 2023 folders hold a clue?
Nope.
Marked @jacob.small 's reply as the solution because that is the best way to handle this. Posting screenshots with no additional information is not helpful at all.
I am betting you are leaving out the fact that you tried to update Dynamo yourself by copying the core runtime files. But, I am not sure as you just posted screengrabs, with (once again) very little context.
Only a new Revit 2023 install on a fairly-fresh-reset Windows 11 plus Revit 2023.0.2 Hotfix.
I just uninstalled Revit 2023 with BCUninstaller and cleaned the Registry with CCleaner. Reinstalled with Create_Installer_RVT_2023_English_WIN64.exe & updated with Revit_2023_1_1.exe … Dynamo Player is now working :sweat_smile:.
Interestingly, I have just incurred a similar issue. Was using Dynamo player in Revit 23 version, hit the edit button within this to open Dynamo full on a specific script. Got distracted by someone, went to close the player ahead of the Dynamo session (probably a bad idea), then my player icon was greyed out and I had no way of coming back from there. Did a program close, without luck. So did a full reboot. Now I have the logo but no sample data. It has removed the content from C:\ProgramData\Autodesk\RVT 2023\Dynamo\samples\en-GB\Revit (not critical issue) but it still shows the folder in the player with a warning symbol even when the folder link has been removed and you can’t click on the scripts, it won’t open them for editing. I guess I am up for a full reinstall required to get things back working correctly! I am guessing it is a bug. Grrr…
