Hi there
Does anybody know why my Dynamoplayer in Revit 2023 is not working at all?
I just click on it and nothing happens but going grey and nothing else ![]()
I have looked for a solution in several posts in this forum and in Autodesk forums but nothing is working for me.
Thank you for your help!
Hi @DavidMena,
I guess it is on an other position outside your screen.
Try to right-click on the taskbar and click on maximize.
If this not works check your registry editor.
And check this website ![]()
Dynamo Player dialog box does not show up when started in Revit | Revit | Autodesk Knowledge Network
Thank you I will try each one of those options and come back to tell you if it worked!
did anyone find the solution for this issue?
I have the same problem without solution.
could anyone advice?
