Hi All,
I’m looking for a similar solution given by @Einar_Raknes (Rebar Cover Settings) but for wall elements.
This is my script:
I can’t get it done, why it doesn’t do the change in all of my elements?
Thanks in advance!
Hi All,
This is my script:
Thanks in advance!
What if you change the lacing to cross product?
I tried this, but as an output I get 225 walls.
try to flatten your list of walls before you connect it to the SetParameter node.
Also tried that one. Now it gives me 45 walls (repeats 3 walls for every parameter). It works, but not the exact solution that I want. I’m thinking that I can make a chain and going parameter by parameter.
