Lateral cover for bars
Hi everyone,
  1. I have the following script and I manage to put the bars at a determined cover relating the bar size, but I don’t know how to do it in the perpendicular faces of the element. Do you know how can I do it?
  2. When I get the wall width, I only managed to get the width from the “wall types” node but if I put the “Model Element” (the selected element from the Revit model), it doesn’t get me the number/parameter I’m looking for. Why?
Thanks in advance!
PD: Try to do this on a single 20 or 30 thick wall.
A
Fierro_Punta_Muro.dyn (31.5 KB)
Hi Jorge,
Similar topic is discussed here Rebar showing up in Dynamo but not being placed in Revit
Kulkul, Hi. I don´t see the similarity to my problem? What am I missing?
Could you drop rvt file or post a link to the file uploaded on Drive, Dropbox, etc…
Kulkul,
Here are the files:
https://drive.google.com/open?id=0B06GJ9aNr2cdd0RhS19peU5qYUU
Thanks!
I tried your script it is working. Can you be more specific what is your query?
For you second question. It is because “Width” is a type parameter. If you need from model element you need to get element type as shown below.
Thanks for your time.
My queries are:
  1. How can I do the cover in the perpendicular face (no the selected)
  2. When you plug the “Select Model Element” node into the “Element.GetParameterValueByName” node, can’t get the info I need (width).
Thanks!
Are you trying to get top surface rebar?
Thanks for the response to the query #2.
The issue with #1:
Hi Jorge,
Are you looking for something like this:
And here is dyn file Fierro_Punta_Muro(Kulkul).dyn (35.2 KB)
Yes! Thanks a lot! I’ve been trying a different -longer- way of the same thing. Thanks really!
