I’d like to create a sheet for each phase I have. I’ve started to do something (attachment) but I don’t manage to “attach” a list of view to a list of Sheet. When I run my program sheets are created but they are empty…
Does anyone have an idea?
Thanks!
Looks like you’re running into one of Revit’s idosyncrasies: You cannot place the same view on multiple sheets (unless it’s a legend).
You will have to create duplicates of the view first. There was no node for that yet, so I made one. Download the latest version of package View Stuff and you’ll find a node called Duplicate View. It will most likely need to be used in conjunction with a Transaction node (see screenshot).
we should have a Like! button.
I agree this is great! All we need is to rename them, set a view template, location on a sheet, and maybe view group/subgroup nodes to make this a fully operational sheet management package.
I might look at that later…
that would be a start, but I am thinking about the same things.
Thank you so much for your node Andreas. It’s exactly what I was missing!
