Hi Everyone,
I’m trying to write this script that allow to insert specific views on specific sheets using Excel’s sheet.
The script works but can’t attach in Revit multiple views.
Just working with one view.
May anyone help me?
Thank you.
Giacomo
I tend to avoid the OOTB node and use Rhythm’s viewport.create node. It does require you to create your sheets prior to placing views on the sheets if you have not done so.
Here is a post I answered a while ago showing how to use Rhytm’s node for placing views on sheets.
Hope this helps!
Hi Patrick,
thanks for the advise.
You said a different kind of script because my aim is to collect from excel both views and sheet name .
May you help me in this way?
Thank you.
Giacomo
Ok solved.
I used the wrong node “Sheetbynamenumbetitleblockandview” instead of “Sheetbynamenumbetitleblockandviews”
Btw thank you @patrick_podeyn
Have a nice day!
