I’m having trouble with the mentioned node. It was working fine for the revit file I originally created the dyn for but when switching to another revit project it stopped working.
Following the fix in the error message, I got it to work, but now the UV Points I originally calculated for the surface are useless.
While seaching google for a fix I found this thread, which I can also reproduce.
Is there an easy fix to that?
What does the error message say?
basically the same as in the linked thread:
Warning: AdaptiveComponent.ByParametersOnFace operation failed. This node requires a ElementFaceReference extracted from a Revit Element! You can use the ImportInstance.ByGeometry to turn this Surface into a Revit Element, then extract a ElementFaceReference from it.
