Hello Dynamo forum,
I’m trying to place adaptive component families making use of a base surface in Revit to retrieve normals for the adaptive points set to By Host, but I am having trouble converting between Dynamo UV, defined in a domain between 0 and 1 and Revit’s UV, defined by the surface’s domain, ( as far as i understand, in feet but I’m not really sure how it really works! ).
I’m using the node: AdaptiveComponents.ByParametersOnFace
How can I convert my Dynamo UVs so I can place the components on the surface?
I think would be great if in Dynamo we could provide a normal vector to adaptive points to orient them even without a surface!
Thanks a lot!
