Problem With Clockwork Package
Hi All,
I’ve been using some of the nodes in the Clockwork Package but I have a constant problem: Every time that I open a new Revit Instance (and Dynamo of course) I have to install the Clockwork package.
What could be wrong?
Thanks in advance.
What is the specific issue you are having?
Check to see if you have these custom packages installed.
Return List Or Single Value
Turn Into List
Dynamo
I was running into an issue, even with clockwork 1.x installed. These nodes seemed to live outside the package as separate packages, but had nodes dependent on them in the clockwork package. Once i removed them the issues went away and the nodes worked as expected.
Also, always install Bakery manually by downloading from DynamoPackages.com. It has an enormous amount of outdated dependencies and messes all sorts of stuff up with other packages.
Thanks both! @john_pierson, @William_Ruffenach
