I’m trying to use the orchid node Print.ByView and it’s giving the error that no views/sheets are selected, even though I did give it a sheet. What could be the problem? (screenshot below)
Hi @sed07,
As I see it, you need to feed it with a view.
Otherwise, it is Print.ByViewSheetSet you’ll need.
I thought of that before and tried it, but unfortunately it gives the same error with a view as well.
And reading the error output, it seems like it’s supposed to work with either views or sheets.
