LFNM
December 2, 2017, 1:47pm
1
Hello everyone,
I’m having a problem with the “Sheet.Views” node.
I want to get the views of a sheet, but when there is a drafting view or Legend on the sheet, I have an error with the “Sheet.Views” node.
I can not find a solution to this problem.
Someone would have a solution.
Thank you
Kulkul
December 2, 2017, 4:31pm
2
Hi @LFNM
Without looking into your whole graph i can say your connecting views to it. Could you show us your complete graph.
LFNM
December 2, 2017, 5:16pm
3
Hi Kulkul,
Thank you for interest in my problem
The first exemple is with Legend on the sheet
With drafting view, the node work.
Kulkul
December 2, 2017, 5:37pm
4
@LFNM Try the other node from Rhythm “Sheet.GetViewportsAndViews” it should read any views:
LFNM
December 2, 2017, 5:56pm
5
thank you,
I had already used in my script the noed package Rhythm, but I did not want dependency. Because all the nodes that I use I integrate them in my package with my scripts so that the users is only one package to install.
And the node “Sheet.GetViewPortsAndViews” is in a dll. This is not a standard custom node and I can not integrate it into my package.
Kulkul
December 2, 2017, 6:22pm
6
In that case use “Springs.SheetViews+” node:
LFNM
December 2, 2017, 8:03pm
7
Yes !
Thank you very much, it was hours that I was looking for a solution.
Kulkul
December 3, 2017, 1:27am
8
@LFNM Next time if you got stuck do come back here our community is to help others. You’re Welcome!
Cheers!
