PolyCurve.Offset to Wall.ByCurveAndHeight, bug or not?
Hi there,
I wanted to offset some curves and place walls on top of the offsetted curve.
the output of PolyCurve.Offset is: ‘Curve’
If I connect this to the ‘curve’ input of the Wall.ByCurveAndHeight-node it doesn’t work.
The solution is even stranger…
I converted the output-curve into a polycurve (PolyCurve.ByJoinedCurves) and back into a Curve[] (PolyCurve.Curves)
I insert that into the Wall.ByCurveAndHeight and it works.
Is there some logic behind the different types of curves:
I have ‘Curve’ (Capital C) ‘curve’ (normal C) and ‘Curve[]’ (Capital C and brackets)
Just curious.
Even one year later, I think it’s worth to mention that I have done this thanks to the tip you once shared:
