Hello there,
i was trying to get pointcloud data with the nodes from Sastrugi Package.
Unfortunately i only get nulls?
Has someone an idea on this?
@Ewan_Opie
greetings
Kev
Hello there,
@Ewan_Opie
greetings
Kev
Hi @KevSch
Can you please provide the following information so I can troubleshoot this one.
It is hard for me to replicate to troucbleshoot the error without the aboce. Also, have you copied the contents of the node to the workspace to see where any errors may be occuring? Might be a versioning / units issue which I have seen before.
I really should do an update for Sastrugi, so little time ![]()
sorry for the late reply… i am running the same parameters as @nishizawaFG597, so i can`t get any data from selecting the pointcloud ![]()
Activating and clicking a node doesn’t seem to select the point cloud data, is there a solution?
・Revit2023
・Dynamo Core 2.13.1.3887
・Dynamo Revit 2.13.1.3891
・Sastrugi 2.0.2
・Placed the point cloud very close to the origin
・Project Basepoint/Survey Point Parameters:(0,0,0)
I’ve been a bit distracted by life in general recently, so very very busy. ![]()
I’ll take a look at this tonight and see what the issue with the code could be.
don’t worry, i understand
thanks for trying to find a solution ![]()
thank you. That helps a lot. ![]()
Is there any update on this issue? I am facing the same problem. Thank you in advance.
Hopefully this will help with this issue ![]()
Hi there
I’ve been using these nodes too but I can’t get it working : I get nulls out of every nodes as @KevSch before
Some information :
Thank you for any input
Hello everyone!
I’m brand new to using Dynamo, and I’m trying to get a program running for modelling pipes from point clouds. I’ve seen that I’m not the only one to have a problem with the ‘Select Point by Region’ node. No matter how hard I try, the function still returns a ‘null’ value.
I’m using Revit 2025, with the Sastrugi 3.0.2 package, and I’ve brought my cloud back to the origin (0,0,0) for the experiment. Is there a solution to make the selection work?
Thank you very much for your help
I do not believe that Sastrugi has been updated for the .NET 8 environment which was updated in Revit 2025 (previously it was 4.8). Anything involving much UI or external components will need to be updated accordingly.
brimohareb package have nodes for pointcloud as well and should work in 25
Ohhh I hadn’t even thought of that. Thanks for your reply, now I know what the problem is! Thank you so much!
I will check that, thank you so much !
