i am a new in dynamo, i try to use the script of @GavinNicholls (thank you for you vidéo) ,for place sphere clash, but when i want to use the node “get project location” of genius loci. is différent then revit 2023
we have not the same result, dynamo put xyz in the same line not like tutorial.
can some one help me to resolve this probleme.
thanks
If you check the comments you will see a lot of people struggled with this. Use the y value of the point for NS and the x value for EW, dont just copy me node for node even if its different. May be worth reading dynamo primer if you havent already to familiarize with the core principles I’m using at this step.
