Hi All,
I’m referring to this topic.
I just get the Clash Spheres approx in the same spot.
FamilyInstance.ByCoordinates accepts x,y,z in metres. If I try to convert to mm I get an error.
My project is in mm.
Ideas?
Change Geometry Working Range to Extra Large.
Thanks @Kulkul that worked!.
Not sure if you want me to open another topic but the issue is now that the sphere doesn’t end up in right place.
I just placed the sphere for clash1
Thanks @Kulkul. The sphere is still not going in the right location.
Revit sample files are here:
https://1drv.ms/u/s!AjD2jKUSZk_2gYUFbkFuAyH2AIulKA
Also I’ve attached the excel and dyn files. Please note I’m just testing the workflow for clash1
Navis to Revit with Dynamo-V2.dyn (28.0 KB)
Clashes from XML.xlsx (13.1 KB)
It will depend on how you get the model into Navisworks
If you are using the NWC exporter in Revit- then check the setting which determines the origin (shared coordinates vs internal)
Also- there are some posts on this forum from me on this topic 12-18 months ago I’d guess
Finally, there is an admin from Kiwicodes (I believe free) that does this task
Andrew
Only if I use shared coordinates (in red), I have the models correctly aligning in Navis
Are you solving the coordinates issue in your posts?
Thanks for the tip but I’m trying to solve this in Dynamo
I can’t remember the details, but I remember doing it
If you post your clash results XML file (straight out of NW) I will take a look
Thanks Andrew. This is the file:
https://drive.google.com/file/d/0ByYuWekrCCcaNWdFVExodUpZcXc/view?usp=sharing
Salvo
there are a few issues.
I would suggest either:
scrap the sample models from Autodesk and create samples yourself. Using internal (origin-origin) is the simplest
or
federate the models in Revit, and manually relocate models (e.g using grids) and export to NWC using the ‘internal’ option and ‘linked models’ options. Run the clash tests on this federated model.
hope that helps
Andrew
Sorry I just saw this reply! OK I will test it with different models
Hi Ramyo
check your units- your ‘convert units’ nodes are converting metres to metres.
This would explain the spheres being in the same (similar) position
(the Dynamo screenshot is showing the points)
Andrew
Thanks Andrew, Got it.
