Hello, I’m new to dynamo. I’m trying to create pannels from an adaptive 3 points family on each face of a Delaunay transformation on a surface from Revit.
How can I achieve it?
delaunayVertices.dyn (6.9 KB)
@mikael.santrolli Have you tried with different parameter values. Does it fail every time?
Upload your file if it continues to fail.
Maybe is an issue with the revit mass face i’m importing.
Here is my file
EDIT: I tried with flat surfaces and your method works. However when I use 3D surfaces it fails.
Triangulation Delaunay.dyn (14.8 KB)
If that’s the case, try this work around …
- Create a flat surface using the curved surface perimeter curves
- Trim the flat surface and get the point groups
- Project these onto the curved surface
