Hello everyone, so basically im trying to getting the shortest path from some point to another point
And im using this method.
Also this Method:
Ive already tried the same way with the tutorial.
the first method im getting trouble at Curves.ShortestWalk by LunchBox nodes. my version: 2018.7.7
I dont know whats caused this, any idea?
The second method using topologic nodes.
So im using the delaunay graph as the topology. im getting null at Graph.ShortestPath. i dont know whats caused this
is there any solutions?
Lunchbox hasn’t been updated since like 2018 - meaning you might as well have to run it off a 5.5" floppy disc (the thing shown by the ‘save’ icon if you’re under 40) to get it to work. I recommend avoiding it accordingly. The message is saying the method which they used to generate the final PolyCurve no longer exists (PolyCurve.ByJoinedCurves) in C#, as there are required overloads for the joinTolerance, trimCurves, and trimLength now. As they aren’t updating you’ll need to find an alternative.
For the topologic issue, I can’t see the problem.
That said, VASA will outperform both of these methods by a good margin, works in 3D with just about any geometry shape, and gives you additional tools for pathfinding such as finding the path without having to build a massive triangulated mesh (in your example you’d need to build an additional diagonal in your lattice). More here: https://www.youtube.com/watch?v=wE4gk0FYWDw
