Hi, I’m new to Dynamo and I’m trying to create an override graphics for multiple selected families(or elements) in multiple views. so far i have found archilab node to hide element in multiple views and one most similar to what i’m looking for is the set element projection line weight.
Is there one that allows me to plug the graphics setting properties like so?
A selection set based filter might be a better option so it can be removed/added on the fly without as much difficulty. But you should be able to make this work as is with lacig and levels enabled correctly.
You could create one filter that applies to the elements, change the override values ( projection line color) and use the “Copy Filter Overrides to Views” node from the Sastrugi package? This copies the settings of the specific filter set in one reference view to other views.
