I am very new to Dynamo and have tied to create a workflow that does the following:
Gets all the elevation views and applies a graphic overide to all non-parallel walls (return walls)
I have tried to filter the walls using a true/false list, but I cannot relate this list to the “element override in view node”. I have a Int but am needing this to go to an Element.
Please see attached workflow.
I cant attached the Revit file at this time as I’m a new forum member.
The walls are just your typical structural walls.
The view has been created by elevation.
The end product will be a precast panel elevation.
