I have designed a script that will automatically halftone/dash-line pipes and pipe fittings/accessories with values for “Middle Elevation” and “Elevation from Level” below -3 feet.
You may ask “Why not make a view filter?” and this is because I would have to make separate filters for pipes and pipe fittings + accessories (they don’t have the same elevation parameters… why??), and then apply that to multiple view templates. So in the end, running a script that could apply this to multiple views seems faster.
However, this only works in the active view. Is there a node that can take a list of views as an input and apply the element overrides in those views?
