Hello dear community, I was doing some routines to overwrite the colors of some elements, until I found the sections where I could not overwrite the elements, although of course if I use a “more classic” method it can be done. perform per-element overwrite
any help is appreciated in advance
Greetings!
Try to modify the elements in the block instead of model space.
Hi @Renato.94 try something here from genius loci…
super! thank you very much for this information
I tried what was proposed and it worked quite well for me, but I have a question, is there the possibility of being able to select the elements globally? or from an active view, considering that in any view there may be several elements other than the section
Greetings!
nice…globally i would try set the object style…think genius loci have nodes for that as well or just do it in object manager …probably faster my exemple do a override in active view
