Open Family and get Parameters
Hello everyone,
i am trying to get all parameters of a family which i open with the node Applications.OpenDocumentFile but the output is Null.
Do i miss something?
Hi @laurin.ernstMA6Q3,
Use instead the FamilyParameter.Properties node.
Hi Alban_de_Chasteigner
I am trying to use the same method which you had mentioned on the post. but I am getting null value value to familyParameters I am not sure where I am going wrong.
Note: I am in learning phase with dynamo I am not sure do I need to start a new thread for solved issue.
Thank you
BR
JJ
Are you using Revit 2022 ? I’m afraid that the Clockwork package (FamilyParameters.Properties node) has not yet been updated for Revit 2022.
Hi Alban,
Yes, I am using Revit 2022 :slight_smile:
Thank you for time.
I will look into it with other version
