Offset Points
Hi All,
I was trying to create an offset of points(outside) by creating first closed polycurves and then offset it outside and the use those points for family instance location, the problem is i cannot get the same order of points as shown.
should be
Any ideas how to do this, maybe a differnt approach, main goal is to offset or move those points outside but in 45d angle
Hi :slight_smile:
Solution number 1 : Take a look at the structure of the Spring node by double clicking on it, and change what has to be changed so your graph function correctly
Solution number 2 : Compare the distances between the first point of your initial curve and each point of your final curve. Then get the index of the closest point and shift the indices of your final list to have it match the initial one.
Home.dyn (20.3 KB)
have you tried with the OOTB Curve.Offset node? In my case it works fine:
PS. When you offset curves, you only get 45° translations if the angle between the segments is 90°.
here’s my graph, not sure if the way i created plolycurves will affect the result? everytime i run it it’s generating diffrent indeces…
python:
`import System
import sys
pf_path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.ProgramFilesX86)
sys.path.append(’%s\IronPython 2.7\Lib’ % pf_path)
import math
import random
from cStringIO import StringIO
sys.stdout = StringIO()
def distL2((x1,y1), (x2,y2)):
“”"Compute the L2-norm (Euclidean) distance between two points.
The distance is rounded to the closest integer, for compatibility
with the TSPLIB convention.
The two points are located on coordinates (x1,y1) and (x2,y2),
sent as parameters"""
xdiff = x2 - x1
ydiff = y2 - y1
return int(math.sqrt(xdiff*xdiff + ydiff*ydiff) + .5)
def distL1((x1,y1), (x2,y2)):
“”"Compute the L1-norm (Manhattan) distance between two points.
return int(abs(x2-x1) + abs(y2-y1)+.5)
def mk_matrix(coord, dist):
“”"Compute a distance matrix for a set of points.
Uses function 'dist' to calculate distance between
any two points.  Parameters:
-coord -- list of tuples with coordinates of all points, [(x1,y1),...,(xn,yn)]
-dist -- distance function
n = len(coord)
D = {}      # dictionary to hold n times n matrix
for i in range(n-1):
    for j in range(i+1,n):
        (x1,y1) = coord[i]
        (x2,y2) = coord[j]
        D[i,j] = dist((x1,y1), (x2,y2))
        D[j,i] = D[i,j]
return n,D
def read_tsplib(filename):
“basic function for reading a TSP problem on the TSPLIB format”
“NOTE: only works for 2D euclidean or manhattan distances”
f = open(filename, ‘r’);
line = f.readline()
while line.find("EDGE_WEIGHT_TYPE") == -1:
    line = f.readline()
if line.find("EUC_2D") != -1:
    dist = distL2
elif line.find("MAN_2D") != -1:
    dist = distL1
    print "cannot deal with non-euclidean or non-manhattan distances"
    raise Exception
while line.find("NODE_COORD_SECTION") == -1:
    line = f.readline()
xy_positions = []
while 1:
    line = f.readline()
    if line.find("EOF") != -1: break
    (i,x,y) = line.split()
    x = float(x)
    y = float(y)
    xy_positions.append((x,y))
n,D = mk_matrix(xy_positions, dist)
return n, xy_positions, D
def mk_closest(D, n):
“”"Compute a sorted list of the distances for each of the nodes.
For each node, the entry is in the form [(d1,i1), (d2,i2), ...]
where each tuple is a pair (distance,node).
C = []
for i in range(n):
    dlist = [(D[i,j], j) for j in range(n) if j != i]
    dlist.sort()
    C.append(dlist)
return C
def length(tour, D):
“”“Calculate the length of a tour according to distance matrix ‘D’.”""
z = D[tour[-1], tour[0]] # edge from last to first city of the tour
for i in range(1,len(tour)):
z += D[tour[i], tour[i-1]] # add length of edge from city i-1 to i
return z
def randtour(n):
“”“Construct a random tour of size ‘n’.”""
sol = range(n) # set solution equal to [0,1,…,n-1]
random.shuffle(sol) # place it in a random order
return sol
def nearest(last, unvisited, D):
“”“Return the index of the node which is closest to ‘last’.”""
near = unvisited[0]
min_dist = D[last, near]
for i in unvisited[1:]:
if D[last,i] < min_dist:
near = i
return near
def nearest_neighbor(n, i, D):
“”"Return tour starting from city ‘i’, using the Nearest Neighbor.
Uses the Nearest Neighbor heuristic to construct a solution:
- start visiting city i
- while there are unvisited cities, follow to the closest one
- return to city i
unvisited = range(n)
unvisited.remove(i)
last = i
tour = [i]
while unvisited != []:
    next = nearest(last, unvisited, D)
    tour.append(next)
    unvisited.remove(next)
    last = next
return tour
def exchange_cost(tour, i, j, D):
“”"Calculate the cost of exchanging two arcs in a tour.
Determine the variation in the tour length if
arcs (i,i+1) and (j,j+1) are removed,
and replaced by (i,j) and (i+1,j+1)
(note the exception for the last arc).
Parameters:
-t -- a tour
-i -- position of the first arc
-j>i -- position of the second arc
n = len(tour)
a,b = tour[i],tour[(i+1)%n]
c,d = tour[j],tour[(j+1)%n]
return (D[a,c] + D[b,d]) - (D[a,b] + D[c,d])
def exchange(tour, tinv, i, j):
“”"Exchange arcs (i,i+1) and (j,j+1) with (i,j) and (i+1,j+1).
For the given tour 't', remove the arcs (i,i+1) and (j,j+1) and
insert (i,j) and (i+1,j+1).
This is done by inverting the sublist of cities between i and j.
n = len(tour)
if i>j:
    i,j = j,i
assert i>=0 and i<j-1 and j<n
path = tour[i+1:j+1]
path.reverse()
tour[i+1:j+1] = path
for k in range(i+1,j+1):
    tinv[tour[k]] = k
def improve(tour, z, D, C):
“”"Try to improve tour ‘t’ by exchanging arcs; return improved tour length.
If possible, make a series of local improvements on the solution 'tour',
using a breadth first strategy, until reaching a local optimum.
n = len(tour)
tinv = [0 for i in tour]
for k in range(n):
    tinv[tour[k]] = k  # position of each city in 't'
for i in range(n):
    dist_ab = D[a,b]
    improved = False
    for dist_ac,c in C[a]:
        if dist_ac >= dist_ab:
            break
        j = tinv[c]
        d = tour[(j+1)%n]
        dist_cd = D[c,d]
        dist_bd = D[b,d]
        delta = (dist_ac + dist_bd) - (dist_ab + dist_cd)
        if delta < 0:       # exchange decreases length
            exchange(tour, tinv, i, j);
            z += delta
            improved = True
            break
    if improved:
        continue
    for dist_bd,d in C[b]:
        if dist_bd >= dist_ab:
            break
        j = tinv[d]-1
        if j==-1:
            j=n-1
        c = tour[j]
        dist_cd = D[c,d]
        dist_ac = D[a,c]
            z += delta
            break
return z
def localsearch(tour, z, D, C=None):
“”"Obtain a local optimum starting from solution t; return solution length.
Parameters:
  tour -- initial tour
  z -- length of the initial tour
  D -- distance matrix
n = len(tour)
if C == None:
    C = mk_closest(D, n)     # create a sorted list of distances to each node
while 1:
    newz = improve(tour, z, D, C)
    if newz < z:
        z = newz
        break
return z
def multistart_localsearch(k, n, D, report=None):
“”"Do k iterations of local search, starting from random solutions.
Parameters:
-k -- number of iterations
-D -- distance matrix
-report -- if not None, call it to print verbose output
Returns best solution and its cost.
bestt=None
bestz=None
for i in range(0,k):
    tour = randtour(n)
    z = length(tour, D)
    z = localsearch(tour, z, D, C)
    if z < bestz or bestz == None:
        bestz = z
        bestt = list(tour)
        if report:
            report(z, tour)
return bestt, bestz
“”“Local search for the Travelling Saleman Problem: sample usage.”""
coord = [(p.X, p.Y) for p in IN[0] ]
n, D = mk_matrix(coord, distL2) # create the distance matrix
instance = “toy problem”
function for printing best found solution when it is found
from time import clock
init = clock()
def report_sol(obj, s=""):
print “cpu:%g\tobj:%g” %
(clock(), obj)
print “*** travelling salesman problem ***”
random construction
print “random construction + local search:”
tour = randtour(n) # create a random tour
z = length(tour, D) # calculate its length
print “random:”, z, ’ --> ',
z = localsearch(tour, z, D) # local search starting from the random tour
print z
greedy construction
print “greedy with nearest neighbor + local search:”
for i in xrange(5):
tour = nearest_neighbor(n, i, D) # create a greedy tour, visiting city ‘i’ first
z = length(tour, D)
print “nneigh attempt %i:” % i, z, ’ --> ',
print z
print
multi-start local search
print “random start local search:”
niter = 10
tour,z = multistart_localsearch(niter, n, D, report_sol)
assert z == length(tour, D)
print “best found (%i iterations): z = %g” % (niter, z)
sys.stdout.seek(0)
OUT = tour`
code from here: Connect the dots
saved by springs again :slight_smile:
