Hello
please , how ican do an offset like revit i have an issue
make closed-loop then make an offset.
how to ?
closed-loop
Polycurvebyjoinedcurves node.
Not necessary, try SmartOffset from the Wombat package instead.
If you want lines to not crossover each other but being offset like revit does, you can join them as a polycurve and offset after that.
You can use PolyCurve.ByJoinedCurves for that.
You can try like this. this was done with some help of @Vikram_Subbaiah previous solution.
offset.dyn (32.4 KB)
