Offset Curve not the sample distance
Hello All. I am trying to create a node to offset lines that are not the same distance, the result is figure 1, is there any way that the result of figure 1 is the same as image number 2? Hope everyone can help. Thanks very much…!
import sys
curve = IN[0]
distance = IN[1]
# Place your code below this line
offset = []
for i,j in zip(curve,distance):
	offset.append(Curve.Offset(i,j))
OUT = offset
Unfortunately most programs don’t have a builtin way of achieving this - need to do some geometry gymnastics. I had the same challenge in Grasshopper as well, I’ve attached my method built in Dynamo instead. It involves hyperextending the curves in an offset state and finding the most likely center segment when they’re all split at the intersections. It gets a bit messed up for very distorted shapes. You could also use trigonometry on each corner for a better but more complex outcome (I’m not going to do it, too complex/annoying!).
It uses one method from BiMorph nodes (Curves.IntersectAll).
find inner.dyn (73.2 KB)
Thanks You :heart_eyes: :heart_eyes:
You don’t know me and I don’t know you, but you solve the last problem that I have for my tesis. I am studying computer science I have the AI models for the tesis only need offset to finish, THANK YOU I will graduate thank to this.
Glad to hear, and you’re welcome! :slight_smile:
