Add GIFs as icons of your Revit buttons in two clicks. Give life to your Revit buttons!
Protect your Dynamo scripts against edition when exporting. Your scripts will be encrypted and only runnable from NonicaTab PRO.
Click HERE to download from Autodesk App Store ( FREE 30 day trial! ).
Important: Update by just installing this new version on top! Do NOT uninstall your existing version or you will lose the configuration of your toolbar.
Choose between two new exporting options:
ONLY RUN ⇢ Scripts are encrypted and they can only be run.
RUN & EDITED ⇢ Scripts can be edited and run.
Tip: Remember if your scripts were not imported as ONLY RUN, you only need to press Control + any NonicaTab button to edit the Dynamo script hosted in that button.
Try for FREE from Autodesk App Store. #nonicaioRevitdynamo#dynamobim#bim
After more than a month improving and reviewing all features in NonicaTab, I am glad to share that the new versions are available in Autodesk App Store.
(This one will not be automatically installed (as usual), as this is a major release, and following auto-updates will only be auto-installed if this new version is installed.)
It includes compatibility with Revit 2025 as well as other improvements listed below.
NonicaTab PRO (v4.7)
· [NEW] Update and new features in Cleaners tools.**
· [Improvement] AI Renderer increase performance and additional exception handling.*
· [Improvement] Hotkeys and Playlist System.*
· [Improvement] Dynamo warnings and errors report improvements.*
· [Improvement] Licensing and auth. system.*
· [Improvement] AI Renderer detection Media Feature Pack dependency.*
· [Improvement] Export default settings.*
*Available only through installer.
**Available in-app with a later version than NonicaTab PRO v4.4.3
Thanks to everyone that gave us feedback and suggestions. It really helps us to keep improving.
Important: To update, only install the new version on top of your current version to maintain the configuration of your buttons. (Uninstalling your current version will remove your toolbar configuration and buttons!).
